Stevo2000 Posted September 30, 2022 Report Share Posted September 30, 2022 (edited) Hi,I bought a 2nd hand rotor which was still in the engine casing and I can't seem to budge the retaining nut. Any tips, trick or remedies for sorting? I take it it's standard Threaded? Edited September 30, 2022 by Stevo2000 Quote Link to comment Share on other sites More sharing options...
Ray Stadia Posted October 6, 2022 Report Share Posted October 6, 2022 On 9/30/2022 at 10:38 PM, Stevo2000 said: Hi,I bought a 2nd hand rotor which was still in the engine casing and I can't seem to budge the retaining nut. Any tips, trick or remedies for sorting? I take it it's standard Threaded? Can you put up a photo? If you mean the half time pinion, I believe it's a right handed thread (in other words, the other way). Also, you may need a specific puller to get it off the taper. I had to for an 897. Quote Link to comment Share on other sites More sharing options...
Stevo2000 Posted October 8, 2022 Author Report Share Posted October 8, 2022 Thanks Ray. absolutely correct about the reversed thread managed to manufacture a puller so I've got that off now. I just need to try and get the original PAL one off now to replace that which is proving just as difficult as the thread inside is chewed up 1 Quote Link to comment Share on other sites More sharing options...
