jsteve1999 Posted August 29, 2022 Report Share Posted August 29, 2022 Hi all Can anyone tell me how to tell if the oil pump is working correctly eg pressures As there is no literature for testing Many thanks Steve E Quote Link to comment Share on other sites More sharing options...
THE DEAN MACHINE Posted August 29, 2022 Report Share Posted August 29, 2022 (edited) 2 hours ago, jsteve1999 said: Hi all Can anyone tell me how to tell if the oil pump is working correctly eg pressures As there is no literature for testing Many thanks Steve E You will see it pumping the oil through the glass when bike is running, if you are still unsure unscrew the banjo that is top of oil pipe to head, oil should come out, don’t do it for long though, do you have reason to think it’s not working ? Edited August 29, 2022 by THE DEAN MACHINE Quote Link to comment Share on other sites More sharing options...
jsteve1999 Posted August 29, 2022 Author Report Share Posted August 29, 2022 Hi Dean Thanks for the reply I have it set up as the jawa instructions say but just wondered if there was an actual pressure test I get the drips in the pump ok and the oil going to to the rockers ok and plenty out the dump valves so it should be fine Thank you again Steve E 1 Quote Link to comment Share on other sites More sharing options...
