Jawa 889-6 Engine Manual Help Please
Mark Hales
Hello All.
Please can I qualify this posting by stating this isn't for a speedway bike, but for my new 1/4 mile sprinter/LSR bike. (I'm a drag / Land Speed racer)
I have a Jawa 889-6-317 engine on the bench that I'm ready to strip and rebuild. (The 317 in "my" engine number) I bought last September from a rider in Wolverhampton. (Sorry, forgot his name)
This is as I understand the 889 is a short stroke 90mm engine, laydown type and oil recirculation rather than total loss?
I'm after a manual / parts list for this particular engine with torque settings etc.
I can find these for other 889s but not mine.
Mine has the cylinder bolted to the cases separate from the head. All others seem to have the heads bolted straight to the cases through the cylinder.
It's been suggested this engine was only made for one year?
Basically, I want to strip this for a bearing rebuild and can photograph everything and write my own manual, but would like torque settings for the head, barrel, cam caps etc.
I'm well aware that engine tuners are "the gurus" for engines and like to keep everything lose to them. But help on non tuning facts and figures would be a great help.
The engine is to be linked to a 6 speed HD gearbox and housed in a custom sprint chassis.
And if it helps, I was a Crayford Kestrels / Hackney Hawks fan in the day. :-) And now visit Lakeside and Sittingbourne...
Thanks in advance.
Mark.
Hello All.
Thanks in advance.
Mark.
Hi Mark
I doubt you will get a manual for the questions/settings you require. As you suggest, these things are safely guarded! However, there is an ex-rider on the forum, 'The Dean Machine' who does his own 'stuff'. I would send him a PM if I were you. Hope this helps.
Clive
Hello All.
Thanks in advance.
Mark.
Try Speedway Service on 01553 829197. you're correct about that model only being made for one year. The studs used to pull out of the top of the barrel before the torque setting was reached sometimes. There might be a link on the Jawa Divisov website for manuals.
