Gerhard Engine
hope not . Formula 2 engines are just as expensive as speedway engines to maintain , they dont ride properly . and on achieving a moderate level of competence ,a whole load of new expense and a new learning curve has to be adopted switching to proper speedway equipment . budget cost engines of a sutiable nature are still available , they are called 2 valve Jawas
You can buy a pre-owned 4 valve Jawa bike for about £1000, or a GM for £1500. 'F2' bikes are a dead letter; apart from the factors above, the ones I have seen are much more complicated than an ordinary speedway machine, and have a radiator!
Variable valve timing by centrifugal force , whatever next ?
If you have ever had a BTH magneto off a Triumph, you will find on the auto advance there is a very similar system, albeit a bit cruder, on the ATD ( automatic timing device) to advance ignition timing according to revs, just looks like a more sophisticated version on the end of the cam shafts.
nothing new just another use for an existing principle . Old idea , new application !
When the Japanese came out with their posi-lube automatic oil injection systems it was only a revamp of what Villiers did on their two strokes in 1927, and the Bradshaw designed , oil cooled 350cc engine of the early 1920's pre-dated the oil cooled Suzukis by nearly 60 years.
Edited by piston197
reading that blurb , it said centripetal , is that just a posh way of saying centrifugal ? . not sure if speedways rules on engines have the same loophole TBH . I know the Ignition timing is supposed to be fixed , but modern boxes advance and retard automatically ,and speedway machine examiners dont have the technology to know whetehr its being used or not
  • Like 1
In very simple terms, centripetal force is inward, centrifugal force is outward.
Variable cam timing, Alfa Romeo & Honda have had that on prouction cars for donkeys years!
Would anyone like to guess how many riders have purchased Gerhard engines to use in the 2016 season? Simple question, As a Newcastle Diamonds supporter, it will be interesting to see if Robert Lambert uses them in the PL.
Exactly. Although most likely to be 3 engines, one for each bike and one spare that can be put in when another is being serviced and that is based on a rider doing one league only......
Plus who can service these engines? Gerhard only? How much would it cost to ship to him? How long would the turn around time be?
Whilst the GM's may be far from perfect the monopoly looks certain to continue.
The idea is the bikes don't need servicing. It's you buy two engines, plonk them in your frames out of the box and race them until next winter just changing the oil and basic maintained. Yes a greater cost to buy one but it doesn't need tuning before you race it and doesn't need servicing every few meetings so over a season you only spend what it cost to buy 2 engines.
At least thats how I remember it being "sold".
Edited by SCB
GM's and Jawas are like Inkjet printers. lose a bit on the initial purchase make a fortune out of replacement parts .
